Front Pan-hard bar extension
1 Attachment(s)
Did a rear pan-hard bar conversion on my D2 a while back.
I've been looking at my front pan hard bar and wondering why couldn't I do the same heim-joint system up front with an extended bar to compensate for my 3" RTE lift? I paid under $100 for my rear bar with 2 heavy-duty heim joints. Has anyone done this? Do you know if the rear bolt size is the same as the front? How the hell would I know want length to get? I'm guessing I'd get a bar about 2" longer with adjustments on each end and go from there with an alignment. I know there are a few vendors out there that sell an extended front pan-hard bar but they are freeking expensive. thanks for any help. Attached is a photo of a similar set up someone did on a Range Rover P38. Found it through a google image search but couldn't find any contact info. |
| All times are GMT -5. The time now is 08:09 AM. |
