Front Passenger Side Clunk
I have a front passenger side clunk! I checked both upper and lower ball joints while the tire was off the ground. It does not make the sound when you turn the steering wheel from side to side when the truck is lowered and stopped either. It makes the clunk while rolling when you turn from side to side. I cant seem to find it. I was thinking shock top but I don't know. It does not look damaged. Any ideas would help.
No probs,
they are easy to check to confirm, just jack one side a "little" then you can simply grab the anti roll bar (sway bars as you guys know them) and rock it.. "any" movement in your bushes will be easy to see.
It's common for the opposite side to the driver to wear out as "you" always make left turns (LHD).........in the UK its always the other side (RHD). It clunks as the roll bar knocks on the chassis. Replace both sides anyway.
elboy0712
03-16-2010 09:47 AM
Young
07-22-2009 07:51 PM
bcolins
10-02-2008 12:36 PM
