Are front and rear differential parts interchangeable?
i believe what Paul was saying was yes, and if you use a rear u joint conversion kit it will drop right in and eliminate the flex joint.
I was always told they used the same ring and pinion which is why front diffs go so often,
your actually putting the power to the coast side of the gears.
but ive been wrong before
jafir (12-11-2015)
Part number for the crown wheel is the same front & rear.
aussiedisco
02-23-2010 07:36 AM
