Front seats and front windows no worky
Old 05-20-2017, 06:50 PM
DivebombInc's Avatar
Default Front seats and front windows no worky
Had to move my passenger seat forward today and flip down back seats to carry something today. When I was done I was returning the seat to where it should be and it stopped. It of course stopped way forward so nobody can ride there. Firstly, is there a manual way to move the seat, and secondly is there a fuse that may not be labeled for seats or windows that may be the culprit. I've checked things that I would assume are related, but all fuses seem fine.
Old 05-20-2017, 07:03 PM
OverRover's Avatar
Did you check the fuses under the seats?
DivebombInc (05-20-2017)
Old 05-20-2017, 07:09 PM
Yes Sir, checked under seat fuses. All fuses look good. Checked 34 and any others that looked like window related fuses. I hear a clicking under the dash on the passenger side when I hit the window switch.
It crapped when I was moving the seat.
Did you check the fuses under the seats?[/QUOTE]
Old 05-20-2017, 07:45 PM
OverRover's Avatar
In the Under Hood Fuse Box, just for giggles check fuse 13 and the fusible links related to the BCU(windows & seat relays) . Can you feel/hear if the power seat relay(under the seat) is getting energized? It isn't much, but it's all I got... Good Luck!
Old 05-22-2017, 09:05 AM
Thanks OverRover, still haven't been able to track this down. Going to try to hotwire the seat motor and get it moved back. I'll keep working on this and post results.
Old 05-22-2017, 01:25 PM
Not getting any light on my tester when I test the window fuses, but the fuses are good.
Old 05-22-2017, 01:38 PM
Okay, I think I may be on to something other than the fact that I need to wear my glasses all the time. Fusible Link 5 is blown. I'm thinking this may be the issue. I stuck another one in there and it popped it immediately. Where do I test or go from there?
Old 05-22-2017, 02:24 PM
Nobody in town has these. Even the LR dealership has to order them. LR wants $22.70 each, $2.95 on eBay.
Old 05-22-2017, 11:39 PM
Dave03S's Avatar
Did you already look for pinched wires under the seat? Sounds like a short and since you were moving seats that is the likely area of concern.
DivebombInc (05-23-2017)
Old 05-23-2017, 04:45 AM
I'll be doing that today hopefully.
Thanks all for the help and advice.
Quick Reply: Front seats and front windows no worky
