Front Sunroof not working....ECU?
Well I've checked the fuses, all good there.
The rear sunroof opens and closes just fine. I've yet to check the motor, however I don't think thats the problem. I can hear the ECU click when I try to close the sunroof, however nothing when trying to open it.
Has anyone ever had their front sunroof stop working due to the ECU going bad? I would think if it was in fact bad, the rear sunroof wouldn't work either....
I've searched the rave, with no answers to my questions.....
It is common for the sunroof ECU to get cracks in it and one or both sunroofs will not work.
Same thing happens to the rear windows, if they both ever stop working that is what it is assuming all fuses and whats nots are good.
You can remove the ECU and resolder the cracked joints and all is well again.
I need to clarify that this is a DI fix only.
The problem ended up being that the front sunroof motor was bad. I had two spare motors laying around from a parts vehicle, I plugged them in and both worked. One of them, however, had not been operated in a while and squeeled/hesitated when i plugged it in. After a few cycles it was completely freed up and worked great. Make sure this isn't the case with your motor when operated free of the load of the sunroof.
Also swap the plugs on the switches just to rule out that there is a either a bad switch or ECU.
glad you got it fixed. i had a hunch it was the motor because you had said it was attempting to move. i think if the ECU was shot it would have no response.
twoxred
10-04-2021 07:07 AM
tsuyoi
09-22-2020 10:37 AM
