Fuel Door
RE: Fuel Door
Camdisco-
There is a metal tab on the inside of the fuel door. this tab is fitted with a small plastic clip which grips the small piston located inside the filler door. The piston retracts and releases this clip when the fuel door switch inside the cab is depressed and the door pops open. For some reason, the clip I got does not fit or I'm just too dumb to figure it out. I'm not alone though, I see alot of Discos going down the road with thier fuel door open.
Thanks
Thanks
RE: Fuel Door
Sorry they arent the best quality but hopefully it helps. Let me know if is the wrong thing but I think its right. The hot water idea will work every time.
[IMG]local://upfiles/5713/E6F292D793A145839872E6AB6E1770D0.jpg[/IMG]
[IMG]local://upfiles/5713/9130FE4E6EED4165B003EEB6C0C2E8FC.jpg[/IMG]
RE: Fuel Door
Holy shnikes!
My 03 Disco didn't have that clip on it when I got it. This makes about a billion times more sense then what I've been doing.
Where have you been buying them?
PS: I was sliding my finger behind the door and pushing the tab back as I closed it. It works, but doesn't stay mounted flush.
