| RicketyTick |
Jul 19, 2014 01:05 PM |
Quote:
Originally Posted by Jared9220
(Post 473450)
I saw many youtube video's doing it that way and it will help get some off the bigger stuff off. Honestly if I was just going to use injector cleaner to try and clean up the injectors, I would hook up directly to the fuel rail and run the cleaner while the engine is running. That would work better than taking them off and using a momentary switch.
OTC makes a great product for cleaning that way and it will run you $140, about what I paid for the ultrasonic cleaner and pulse timer together. OTC 7448A Fuel Injector Canister-Type Cleaner
But from everything I've read the absolute best way to get the injectors back to like new condition is by running them while in an ultrasonic cleaner. Unfortunately a hand activated switch was not going to get the job done.
Different strokes for different folks.
yea I've seen the vids also, with the syringe and battery and all, and have looked into the on engine cleaners as well. I am wanting a good setup like yours. Looks like the right way to do it and nothing worse than putting something back together just to find out the job wasn't done correctly the first time.
My daily driver has a vacuum leak or injector leak or clogged injector or something now.
I was about to tear into that and change the o-rings and half a** clean them but would be good if I had a setup like yours before I do.
It's because I didn't do that when I had my engine apart before, now I have to take it apart and do what I should have done to begin with. I can partially blame that on the place I bought my head gasket set from, as it was supposed to have the injector o-rings included and didn't and I had already pulled my injectors out when I noticed that they were not in the box. so, I just put them back in with the old ones and as a result I now think they are not sealing good.
I'm always tinkering with engines and will always have some that need cleaning. I have 3 rover engines now, two running and one apart, and all could use an injector cleaning/rebuild i'm sure.
I think that's something that will pay back for itself many times over. Not having to pay someone else to do the job or buy rebuilt is worth more than the cost. Then every time I have an engine apart I can go ahead and clean/rebuild the injectors for good measure and not have to wish I had.
So are you happy with your choices of the cleaner and timer? If you could do it over would you buy the same or is there something that yours don't have that you wish it did have?
