Funny wear on rear pads
Stumped by the condition of my rear pads. Land rover discovery 2. Back brakes were getting kind of weak. Pulled off the back left and found the inside pad next to piston completely warn. The outer pad 80% new. Tested the slider pins and one was seazed. Figured that was issue. Used c clamp and pushed piston in with out issue. Pulled off right wheel and examined the pads. Same issue. Inner pad warn completely and outer with plenty of pad left. However both pins worked as normal. Pushed piston in with c clamp without issue.
Why was the inner warn and not outer? If the piston had seazed would I be able to push in easily with c clamp?
Check the mounting brackets that hold the pads in, I had mine have a worn spot where the brake pads ride on. There was a noticeable valley that was keeping the brake pad from mpving as it should. I wish now I would have taken a picture to show. But i was getting crazy squealing with new brake pads, I resurfaced with a file just enough to give pad a smooth surface to ride on. Afterwards no squealing and it felt better when braking. Just an idea,
Jose
Jose
Jose
Jose
