Garage door opener
Ok... I cant find the programing instructions anywhere... Would anyone shed some light on this for me please.
Thanks. |
I found this online. Apparently it is from the Rave CD though I haven't confirmed that.
Here is a complete homelink programming guide: Here goes a long c/c/p If you have any problem programming it, call LR Free Tech Support: 1-800-355-3515 If you have previously programmed your HomeLink® Transmitter, proceed to step 2. Otherwise, hold down the two outside buttons on the HomeLink® Transmitter until the amber light begins to flash. Release both buttons. 2. Decide which one of the three channels you want to program. 3. Hold the end of your hand-held transmitter against the HomeLink® Transmitter (underside of the mirror) so that you can still see the amber light (see illustration). 4. Using both hands, push the hand-held transmitter button and the desired button on the HomeLink® Transmitter. Continue to press both buttons through step 5. 5. Hold down both buttons until you see the amber light on the Land Rover HomeLink® Transmitter flash, first slowly and then rapidly. It indicates that you have successfully programmed the HomeLink® Transmitter to learn the new frequency signal. Release both buttons once the rapid flashing begins Operating HomeLink: Operating the Land Rover HomeLink® Transmitter Once it is programmed, the HomeLink® Transmitter can be used in place of your hand-held transmitter(s). To operate, simply press the appropriate button on the HomeLink® Transmitter. The amber light comes on while the signal is being transmitted. NOTE: If your hand-held transmitter appears to program the HomeLink® Transmitter, but does not open your garage door and, if your garage door was manufactured after 1995, your garage door opener may have a ‘code protected’ or ‘rolling code’ feature. A ‘rolling code’ type of system will change the ‘code’ of your garage door opener every time you open or close your garage door. To determine if you have one of these systems, depress the button on your HomeLink® Transmitter that you programmed. If the amber light on the HomeLink® Transmitter flashes rapidly for 1-2 seconds, then turns solid, your garage door opener has a rolling code system. Training a garage door opener equipped with ‘rolling codes’ To train your ’rolling code’ garage door opener to operate from your HomeLink® Transmitter, follow these steps: 1. Program your hand-held transmitter to the HomeLink® Transmitter by following the procedures outlined in ‘Programming’, page 97 (if you already completed this programming, proceed to the next instruction). 2. Train your garage door opener receiver to recognize your HomeLink® Transmitter: (your garage door opener receiver will learn to recognize the HomeLink® Transmitter by following the same process used to train the hand-held transmitter) a) Remove the cover panel from your garage door opener receiver (the receiver should be located by the garage door motor). b) Locate the training button on the garage door opener receiver. The exact location and colour of the button may vary by garage door opener brand. If you have difficulty locating the training button, reference your garage door opener manual, or call 1-800-355-35215. c) Press the training button on the garage door opener receiver for 1-2 seconds. d) Return to the HomeLink® Transmitter in the vehicle and depress the programmed HomeLink® Transmitter button for the duration of the rapid flash of the HomeLink®’ amber light, (1-2 seconds). Release the button and depress the button to confirm that the HomeLink® Transmitter has been trained to the receiver. e) Your garage door opener should now recognize your HomeLink® Transmitter. You may use either your HomeLink® Transmitter or your original hand-held transmitter to open your garage door. If after following these suggestions you still have difficulties programming your HomeLink® Transmitter, call toll-free for customer assistance: 1-800-355-3515 Erasing channels To erase all three programmed channels, hold down the two outside buttons until the amber light begins to flash, then release both buttons. Individual channels cannot be erased, but can be reprogrammed using the procedures for programming the HomeLink® Transmitter (steps 2 through 5). NOTE: Be sure to retain your original transmitter for future programming procedures (i.e. new vehicle purchase). When selling your vehicle, be sure to erase all channels on the HomeLink® Transmitter that you programmed. Accessories Accessories for your HomeLink® Transmitter are available from the manufacturer of the device. If you would like additional information or would like to purchase other accessories such as home lighting or security products that can be operated by the HomeLink® Transmitter, please call the toll-free: 1-800-355-3515. |
Yup, thats how its done.
Thanks for the info.... I cant find it in the Rave CD. If someone could show me where it is that would be awesome
Dont meant to hyjack the thread but im gunna anyway lol
My disco didnt come with the homelink, but i have a homelink module that i obtained. it has 2 wires comming from it. i havent pulled the plastic panel out yet but is there a harness up there ready to plug in or will this have to be spliced in somewhere to the light dome wireing? |
The harness should be there, the same harness was used for all models. Now you may have to fine a relay or fuse to power that part of the harness. If no luck you will have to get power to the "homelink" from the dome light or other source. Investigate what you have now and remember that the harness may have vibrated down over the years so you may need to do a little fishing to find it.
Originally Posted by lr2001silver
(Post 361665)
Cool, think ill make that my project tomorrow if its not to cold out... I got tired of my ancient hand held one that came with the driveway door more then 2 decades ago now haha
