Gearing up and down
Old 02-06-2019, 02:25 PM
Received 1,131 Likes on 781 Posts
You can manually change from D to 3 to alleviate the problem. And at what speed and RPM if you are at, under low RPM and light throttle kickdown can be delayed unless you goose the gas. At hi-way speed I never have an issue only driving around town, we have some steep hills,right after traffic lights and no lead up, so sport mode or manually changing gears works best for me in those conditions
Old 02-06-2019, 03:25 PM
NewToTheTwo's Avatar
Is the downshift only initiated by load or throttle position?
If he was at a steady throttle position the entire time, it might explain why the downshift was delayed.
I'd want to try it again and add throttle and see if it responds better.
Old 02-06-2019, 05:23 PM
Philip Chan's Avatar
Originally Posted by acg
Where are you located?
I'm Mission...BC
Old 02-06-2019, 05:26 PM
Adding throttle def. kicks it in. If I coast into the hill at 70 and try to maintain it, it slows, slows slows and gravity does its thing. Then I put the foot down and it powers up and shifts down.
If it were a manual transmission, I would have shifted to third by that time for it to take me up the hill w/o stalling.
All I am trying to do here is figure out if there's an issue or not - or if this is a normal disco 2 thing...sort of work out the character and sort it from the broken.
Old 02-06-2019, 05:29 PM
Sounds about right - I see you're from Mission too? . if you are, it happens to me on the stave lake street hill just after the school heading north. Also happens on Doyle heading up to Richards.
Old 02-06-2019, 06:42 PM
Other side of town but yea that hill is tough, sounds like you have the same problem I did drove stick for too long. I have to punch it or drop to 3rd on that hill too, if helps.
We can meet up day and compare if you like
Old 02-11-2019, 11:26 PM
I really did not see any difference with sport mode. I just drop it to a lower gear.
Happy Landrovering from northern Vancouver Island
Old 02-12-2019, 05:38 PM
Big Jim Swade's Avatar
What size tires are you running? Mine became noticeably more sluggish by going from a 29" tire to a 30" tire. If you're running something taller, it will prolly be more pronounced.
Old 02-12-2019, 07:15 PM
acg's Avatar
acg
acg is offline
Originally Posted by Philip Chan
I'm Mission...BC
I thought your name sounded familiar to a BC Roverlander who frequents our forum. I am in Chilliwack.
treadhead
02-04-2019 09:49 PM
archaeology_student
09-08-2014 08:07 AM
tbendekovits
02-28-2014 10:52 AM
kerryslemon
10-21-2011 04:45 AM
ahandysafeunit
12-30-2010 08:30 PM
Quick Reply: Gearing up and down
