Got some codes today
I knew it wouldn't last. Eventually the SES light had to come on. Well, it did. Got codes P0560 and P1668. Thinking those codes might be related to the severe (and I do mean severe) thunderstorm early this morning. (even my front yard was flooded and that doesn't happen often) Maybe my Disco was in the proximity of a lightning strike :D Anyhow, I made several stops around town today (about 7) Constantly shutting off and starting the vehicle with no problems. Had to do some searching for the P1668 code. I found 2 results: One says "PCM-IDM comm fault" and the other says "Anti-Theft Alarm serial link fault Drive cycle A:Signal out of range - above maximum." For now I've cleared the codes and see if they come back.
Eric |
fingers crossed it was a one off thing
Guess it wasn't a one time thing :( 3 weeks later and the code came back tonight while I was driving around. Looks like the only remedy is a trip to the dealer. I'm going there on Monday to have an alignment done so I'll see what my options are. I'm hoping it's just because of the battery.
Eric |
your BCU might need to be reporgrammed or replaced.
- Unlock the vehicle and wait one minute. - With the ignition off, verify that the anti-theft alarm LED blinks slowly. - Turn the key to position "II" and verify the alarm LED is on continuously. This indicates an immobilized condition. - Check that Passive Immobilization is on by attempting to start the vehicle with the LED on continuously. - If the vehicle does not start, confirm that Passive Immobilization is turned on as follows: ^ Turn off ignition and remove the key. ^ Press the unlock button on the plip once. ^ Attempt to restart the vehicle within 30 seconds. ^ If the vehicle starts normally, Passive Immobilization is activated. The BCU must be replaced or reprogrammed by Land Rover |
