-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   grease nipples (https://landroverforums.com/forum/discovery-ii-18/grease-nipples-10406/)
willstevens Dec 6, 2007 07:12 PM
grease nipples
driveshafts , u joints ...
is there a complete list and location for all the grease fittings?
Disco Mike Dec 6, 2007 08:18 PM
RE: grease nipples
You have, or should have 4 grease fittings on the front drive shaft, one of the front u-joint, should have 2 on the back side of the front drive shaft where it attaches to the t/case and on on the slip joint where there is currently an allen plug. On the rear shaft you have one grease fitting on the u-joint and should add one to the slip joint where there is now an allen plug.
willstevens Dec 7, 2007 04:56 AM
RE: grease nipples
so just the shafts and u joints, no other joints or axles or anything? That should be pretty easy to manage.
Disco Mike Dec 7, 2007 10:25 AM
RE: grease nipples
At your mileage, I would suggest you crawl under your truck, and inspect the roto flex that attaches the rear drive shaft to the rear diff, looking for cracks in the rubber between the bolts.
willstevens Dec 7, 2007 01:37 PM
RE: grease nipples
The roto flex is on order. I will handle that project myself. So no other grease fittings that I need to know about?
Disco Mike Dec 7, 2007 01:39 PM
RE: grease nipples
No, but who are you going to have do the rebuild on the double cardon?
willstevens Dec 7, 2007 01:49 PM
RE: grease nipples
Cincinnati Driveline did it yesterday.
Disco Mike Dec 7, 2007 02:53 PM
RE: grease nipples
OH good.
willstevens Dec 7, 2007 04:13 PM
RE: grease nipples
grease-able naepco joints and cv ball kit. I listed the part numbers in another thread. Parts and labor was $216.00. balanced and out the door. thanks for the help. I am on my way out here shortly to pick up the Disco from the shop that did the gasket work. mostly preventative maintenance stuff but it started with the search for the coolant leak.
