Lol
Originally Posted by Camdisco24
(Post 181586)
def having something like mesh to keep stuff out.
Have you ever looked at putting on a side vent? Here's one: http://www.simmonites.com/vehi/mark%20new%20wheels.jpg (Ignore the wheels) about the h2 hood vent, i think there is only a inch clearence from the hood to the intake.... I would opt for side vents...You would need some kind of scoop to push air up to the engine compartment to get a flow to move air out. Thats how nascar cars work in principle... looking forward to see you cut up that hood though... I would suggest you getting one from a wreaker to experiment with before you bucher yours beyond repair...:eek: I know a guys who has alot and could probably get it cheap....;) |
i'm gonna do it...this week....i need some cutting wheels first though...
the thinnest part of the vent is 1/2 inch...i'd make the rest fit....plug i wont have the thermal blanket on the hood anymore also |
Id say go for it. you got balls..
i just still dont like that your using a fake vent. first make sure you can vent it. |
If you can restore the thing from a fire you can certainly add a vent!
TAKE PICS. |
i'm gonna cut the vent up first and make it functional...then i'll pull the hood and measure with laser and chalk set and then cut....
Originally Posted by 03discoman
(Post 181582)
i dont want a cheap looking vent.... that kinda stuff belongs on jeeps.....
i think i like this....do you guys think i should fill in the handle are with wire mesh and open it up for even more air flow I like it, X2 on the hood blackout, painted, no need for you to buy a $90 decal just to hack it up. I vote YES for the wire mesh. Now when you are cutting on the H2 "vent" making actual vents are you going to make some sort of trap or gutter system so water and pine needles, dirt, bird crap, etc, aren't dropping straight down onto the engine? |
the Side vents cant work..... the location of the vent illustrated in that pic is BEHIND the fire wall... check it out.
Originally Posted by jycsalas
(Post 181735)
Wow, I was just at www.hummer.com and the H2 comes with a 6.2L V8, who in the hell needs that big of a engine unless you are a contractor and you need to pull a heavy load with your 1-ton pick up every day of the week.
I mean seriously? Soccer mom needs 6.2L's of gas guzzling Republican oil embedded power? The 454 cid is 6.6L, so that has to be what, around 400 cid? No wonder GM went bankrupt. Everything Hummer but the H1 for the military is absolutely ridiculous and a huge waste of space. I do not like the vent. |
2nd place
Originally Posted by Spike555
(Post 181756)
| All times are GMT -5. The time now is 05:20 AM. |
