Hard Starting
Finally bothered to get everything taken apart and popped the new injectors in. Is there a way to pressurize the system without bolting everything back together? I definitely want to leak check while everything is visible and accessible. Especially the ancient fuel feed line at the bottom of the rail
Oil diluted by gasoline will undilute itself when it gets warm for a while. Deliberate oil dilution with gasoline on light aircraft engines is common (at least it was when I used to work on light aircraft in northern Canada), so you could start the engine the next day. In the morning you would simply start and run the engine for a while to evaporate the fuel.
Having said that, an oil change won’t harm your engine.
JohnZo (08-16-2022)
