Harmonic Balancer
I was told over the weekend that I needed a new Harmonic Balancer. The front seal is leaking oil due to a groove in tha balancer. Of course there goes another $350 or so. Is there any type of sleeve you can use instead of buy a new balancer or is it better of getting a new one. Any input would help.
RE: Harmonic Balancer
The front seals do go out but the only timeI have seen it going out
due to a harmonic balancer, is vibration with the HBbeing loose. If you did not see this yourself, look to be sure. HB are not something that gets changed " unless it has a rubber core some new GM's" they just don't go bad. If it is in need of replacement you have found it will not be cheap. On my Disco I the HBwould cut the front cover. The Disco I HB looks to be all steel. Sorry I was not more help. |
You are correct about them not going out often. Everyone I talk to say it is a rare occurence. Unfortunatley I think the car is snake bit. Everything that is rare appears to have gone wrong so far. Thanks for the input though.
Sorry to here that, I hope that it gets better.
FYI some applications do have a repair sleeve for the groove you speak of. It comes with the new seal for the front cover.
