Hayden fan clutch & original fan?
Old 08-13-2022, 08:30 AM
Toms's Avatar
Originally Posted by Richard Gallant
@Toms yup that combo is loud but it works - after a long hiway drive when you stop at a light the temp will go up, if the air is on even more. Ac seems to add about 6 to 7 degrees to engine temp on average.
Thank you... if I had any doubts because I don't want to have a problem with the heads, although everything is new, even the head gaskets.
  #22
Old 08-13-2022, 09:20 PM
Toms's Avatar
Originally Posted by mln01
I'm not seeing a problem here. What do you not like? The temps are fine.
today i used the original fan and temps were 177 to 188 without the roar of the 2991 max 198 in traffic. my oem fan is not bad, I don't know whether to leave it and later give the Hayden another chance, or return it and change it for the 2781. what do you recommend? I still need to put in some new wires and plugs.
CollieRover
08-17-2022 10:09 AM
austinlandroverbill
05-27-2018 11:14 AM
CollieRover
07-16-2016 01:51 PM
Scharfire
08-30-2012 06:36 AM
Quick Reply: Hayden fan clutch & original fan?
