Head Gasket ???????????????
Old Jul 18, 2008 | 06:28 PM
LR1 Tim's Avatar
Default Head Gasket ???????????????
Hello everyone I have a 1997 SE7 Discovery 1, she has 113,003. miles and I think I blew the head gasket today. I may have done this out of ignorance so please don't hold back let me have it cause when my wife finds out I'm dead, I was cleaning the throttle body per can instructions I disconnected intake from the MAF and sprayed in the cleaner no more than four seconds started and reved the engine and bam a cloud of steam, seems to be coming from back of engine, looked closer and found coolant around the valve covers checked oil doesn't look cloudy. I let it cool down filled up resevor and again runs out the back after warm up. Can an amatuer fix this talk to an indy and he said 3 weeks and $2700.00 Please all help is welcome.
Old Jul 18, 2008 | 07:52 PM
okdiscoguy's Avatar
Default RE: Head Gasket ???????????????
So you are loosing coolant? Check the hoses going to your throttle body. There is a pre heater in yout TB. Check it first
Old Jul 18, 2008 | 08:21 PM
Yeah, do a pressure test first. AutoZone has loan a tool, you can borrow a PSI tester and look for the leak.
Cleaning the t-body had nothing to do with it.
How high did you rev the engine?
Old Jul 18, 2008 | 08:27 PM
LR1 Tim's Avatar
Well I was just pumping the throttle and I guess it cleaned up and then it jumped to about 5500
Old Jul 18, 2008 | 08:49 PM
I'm not sure what the rev limiter is set at...if the gasket was going south the over revving the engine could have finished it. But pressure test the cooling system first.
Old Jul 20, 2008 | 10:02 PM
LR1 Tim's Avatar
It is fixed, I had it pressure tested two BY-Pass hose blown $80.00 and she is fixed thanks to everyone for the suggestions what a great site.
Old Jul 21, 2008 | 04:42 PM
Glad to hear that it is fixed and for cheap.
mike111
Jun 2, 2014 08:58 AM
FlyingZebra34
Apr 25, 2013 08:04 AM
jpmiller
Sep 26, 2012 06:32 AM
dancedisco
Feb 6, 2012 06:34 AM
jcostello
Nov 2, 2006 10:28 PM
