Head gasket job Questions
Old 05-09-2018, 06:52 AM
Saturnine's Avatar
Did you try using the back side of a fresh razor blade to make sure you scrapped it all off? I had a few stains / marks on my block -- just scraped, scrubbed with SB and then said f-ck it and moved on
Originally Posted by CollieRover
Then I should be good to go. Is it ok to still see sort of an impression of the old gasket? There is no material there. At least there does not feel like it.
  #122
Old 05-09-2018, 08:03 AM
CollieRover's Avatar
I used a plastic scraper, lots of WD 40 and a green scotch brite. I used a dull screwdriver to help with carbon on the pistons, but not on the gasket surface. I will try this gently and see if anything changes.
I am being neurotic, but if you look at the picture I posted does that bolthole look OK for install? Or do I need to go over it again?
  #123
Old 05-09-2018, 08:09 AM
Saturnine's Avatar
Dude, I could eat off of that. I’m sure your fine
  #124
Old 05-09-2018, 08:16 AM
abran's Avatar
I use a large flat knife sharpening stone, the fine side on the block mating surface.
  #125
Old 05-09-2018, 08:47 AM
Yeah, man. Automotive Neurotic over here. I am going with it. I have done the best I can I believe. The bolthole have been brake cleaned, blown out, vacuumed and q-tipped. I don't think there is any way the studs don't seat well.
Aside resurfacing the block I don't thin the surface can get cleaner honestly. I don't think I am going to attempt that.
Good news is that my Fan Controllers temp sensor can fit on an empty bolt at the back of the cylinder head. So that should be a little more accurate.
  #126
Old 05-09-2018, 09:58 AM
Saturnine's Avatar
You should probably chase the threads in the block for the head bolts — can’t hurt. Just use an old head bolt and cut a groove in it. DYI tap
  #127
Old 05-09-2018, 02:20 PM
I did that. I got them on. Hint, don’t put the studs in, maybe one to guide, until the gasket and heads are on. Not enough room.
i got them to 70. And double checked them. They should be good to go.
  #128
Old 05-11-2018, 06:09 AM
Reading through the RAVE and my next steps. It says to lubricate the new "Coolant Rail O-Ring" but does not say what to lubricate it with.
Oil? Coolant? Water? Any ideas?
Did some searching, found it should be a silicone lubricant. I do have silicone grease, so I will have to check and see if that will work.
I have lithium grease, so am going to have to source some lube.
After research I am going to get some Plumber's Grease at Home Depot. They have high temp.
  #129
Old 05-11-2018, 07:15 AM
More dumb questions. Can anyone tell me what these parts are for?
  #130
Old 05-11-2018, 08:37 AM
abran's Avatar
Trash, except for top right seals. Those are valve stem seals for the heads when they are rebuilt.
Quick Reply: Head gasket job Questions
