Head gasket kit
Totally awsome!!!!! got a local lr mechanic to do my hg job on the side for 7 bills and a bottle of glenfiddich! (not including hg kit from dap) still what I think is a good deal!(im sure it that helped that he is a former marine like me).Thanks for the hg info and as usuall thanks Disco Mike you are the best!
The bleeder screw comes with the updated hose kit, When you guys remove your heads you may want to pressure check the block to see if your sleeves are leaking coolant at the top of the liner. I have the engine pulled on our DII because of this problem ( I replaced the head gaskets first, dident fix it!) I saw a block pressure check kit online for the 4.0 and 4.6 designed for checking after the heads are removed. If I can use my block I plan to re-sleeve with w/top hat liners, this is to insure that the liners will not drop in the block. I'll keep you posted---------------jneil
