head gasket question
Use common sense.
You need a #3 or #4 Phillips to get the oil dip stick tube mouinted back to the block.
If you loose that screw, it will be hard to replace.
Study how to tighten the head bolts carefully.
First time around on the bolts 15 foot pounds.
Next time around turn them all 90 degrees.
Third time around all 90 degrees again.
I used a pipe - a gas pipe actually from Mc Guckin Hardware in Boulder, CO to give me leverage.
Flickr: Landroverdude2's Photostream
Hopefully you put in Victor Reinz head gaskets..
