Head Unit finally ate a tape, Is there an oem solution with an AUX input?
i've used the grom aux port on two different discos for the last couple of years. sound quality is excellent. i'm assuming that their bluetooth adapters use the same line-level interfacing into the head unit.
keeping the oem head unit also means that you retain the functionality of the steering wheel volume controls.
https://gromaudio.com/store/accessor...eless-btd.html
https://gromaudio.com/store/usb_adap...apter-kit.html
Are these the two pieces I need to make this happen? Looks fairly simple
By the way, it looks like if you add this https://gromaudio.com/store/accessor...ble-35usb.html you get the 1/8" jack PLUS a 5v USB charging port for $15.
