Headlamp Turn Signal Switch
I'm trying to replace my headlamp switch on my Disco I. I removed the steering wheel shround and unscrewed the two small screws that seem to hold the switch in. It's definitely lose in it's housing but I can't get it to come out now. Does it just pull out sideways after removing the screws or is there more that needs to be done. It almost feels like it is held in with tabs from being popped in, however I'm not for sure and I was afraid of forcing it and breaking it.
Anyone know how to remove this?
Thanks everyone
Thanks everyone
I forgot to add that I looked at Rave but couldn't seem to find anything about the removal of the switch. The only place I saw anything was under the steering section but it was talking about removing the steering column in which the entire assembly, both switches included, were removed at once. There has to be a way to remove just the switch, I'm just not sure if it requires breaking down the steering wheel.
Whenever I go to the junk yard I come back with enough stuff to build a whole other car.
One time at the dump I went with half a trailer load and came back with a full one.
How did you remove headlamp switch?
Thanks everyone
Thanks everyone
I have the same problem. How did you get the switch out? Thanks
95Discovery
06-20-2006 02:56 PM
95Discovery
01-10-2006 09:41 PM
