Originally Posted by hilltoppersx
(Post 209757)
its not active because he re-scanned and re-started the truck.
every time you plug the amigo in. how many times did you plug it in?
(Post 209806)
So plugged it in. Let it do its thing. Was going to go in and read it but thought I woudl start the truck to see how a dash looks with no christmas lights. Noticed that I was down to two. Repeated process until all three were gone. |
So far today I have driven around 30 miles. No Amigos yet.
if they didnt come back on then you need to replace the hub. one last thing did you check the connection of the sensor to the harness to make sure its clean and tight? if so then on to the next step. the hub comes with the sensor built into it. depending on how much you drive it or how rich you are will help you make your next decision. new hubs are $400, obviously will last you a long time. a used hub from someone like Will Tillery will cost you around $80 and not last as long. For someone like me who uses my truck as a trail rig and not my DD i go with a used....
(Post 209831)
(Post 209831)
Definitely want to continuity test your sensors just for the fun of it. |
honestly if i were you i wouldnt order anything until they came back on. when it does come back on i would read them again and if you are getting the same sensor error i would buy a used hub. then again my rig is not my DD
(Post 209855)
Thanks to everyone for the responses. Now that the issue is at least put on hold and I can reasonably assuem to get out of park I will get back to the coolant leak. I was unable to determin where the leak was at so far I suppose I need either a scope of just have the local mecahnic take a look. I was told they woudl do the check for an hours labor so that might be an option because I cannot see the leak. |
Yeah, that's probably a good idea. It would be even better if an independent Rover shop could diagnose it for you...sometimes I don't trust the local mechanics with Rovers. Bottom line you just have to trust the guys you ask to give you a diagnosis.
| All times are GMT -5. The time now is 02:40 AM. |
