Help 2004 la/ro disco 2
So i have a 2004 land rover discovery 2 with 87000 miles on it
it had the head gasket done at 67000 the car is amazing and i love it but,
the amount of check engine code that popped up almost blow my mind
I REALLY NEED HELP im a college student and i and in need of inspection
the 2 amigos is on but i will take care of that this weekend
p1000(86)
p0413
p1482
P0444
P0447
P1457
P0102
P1591
P1000(10)
P0154
P0135
P0155
P0140
P0257
P1000(14)
P1000(4)
P1000(75)
P1000(62)
P0159
p1000(86)
p0413
p1482
P0444
P0447
P1457
P0102
P1591
P1000(10)
P0154
P0135
P0155
P0140
P0257
P1000(14)
P1000(4)
P1000(75)
P1000(62)
P0159
Reset the codes, and then check your battery voltage, both engine off and engine on.
Your engine off voltage should be somewhere in the neighborhood of 12.6v, and your engine running voltage should be north of 13.8v.
If you're lower than 12.0v engine off, your battery is likely shot. Lower than 13v running, your alternator is either not charging, or on it's way to not charging.
Ok, once you reset the code, those codes should pop one at a time but not all. It need to cycle few times to get all those at once. I'm just saying that once you get the SES light on, there should be some pending codes still getting ready to tell you they are coming and ready screw you more. So, reset and wait until you get codes again or even the pending ones.
will.tillery
13
05-21-2016 08:16 AM
alti
03-13-2013 08:30 AM
Speed racer
10-11-2008 10:56 PM
