HELP !! Disco II Transmision failure
Good day, i hope someone can help me, I have a disco II that we took the engine out to change the crankshaft oil seal And other seals and now with the motor back on the tranny won't work not on drive or reverse it Will not move at all we try taking out the tranny's fuse and back on as someone told me to and nothing happend thanks for you're help
I'm guessing you left the torque converter bolted to the tranny. Did you use care when lowering and backing the engine to the transmission? You need to insert the output shaft halfway into the torque converter, the rotate converter a quarter turn (I think) and continue insertion. You may have damaged converter or seal.
