Help with my 2000 disco 2 tranny
I just bought a 2000 discovery 2 for my wife, got a good deal because it needed a fuel pump. I ordered a fuel pump and had it put in got it started was running rough (would only idle) had a mechanic put his computer on it and it needed a Mass Air Flow sensor got that ordered and installed along with new plugs and it seemed to run fine. It had a little issue with tranny slipping on inclines so I figured I would check the fluid and it was black (like burnt motor oil) since it was the day before Christmas I figured I would change the fluid. After I did that it would not go into gear, when I put it into any gear it is almost like being in neutral there is a small hint of change. Please tell me I won't need a new transmission.
I use a mobile mechanic I've used him before on my other vehicles and he's pretty reliable for minor stuff. It's working now new filter and "9" quarts of fluid. It made a pretty big difference in the shifting still has a little hesatation shifting from 3rd to 4th. Thank you for responding. I still have some things left to do to it I have the three amigos lit up on the dash still have that to figure out
