Help please asap, car won't start!
I am stuck and have been trying to start the car and no luck.
Car is turning over, following light on in gauge cluster,m and s green lights flashing, oil light on, battery light on, descent light on and red light on for temp gauge(needle is on blue)
I took apart and cleaned terminals, scubbed them and grounding points.
Car has 109k miles.
Please help!
*resolved, see below posts. New battery installed and car started. *
Car has 109k miles.
Please help!
Ok was at autozone and upgraded to duralast gold with 800cca, brought home and installed. Car started up on first attempt.
Spike, dark here in NYC and just saw your message. Will have my mechanic check on Monday.
Is it possible it was the battery? Was about 2 years old, duralast with 650 cca.
Before I went to autozone, I cleaned terminals with baking soda and water and then a scouring pad and all the cables and grounding points. I checked all connections and fuses. I really clamped down the connections and still no go, just turned over.
Truck was in park, shifter and cluster showed park and red light next to shifter was red. I shifted to N an tried starting with no luck.
I drove about 30 miles, and ran fine, will keep you guys updated.
