-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   HELP! Starting issue stumper 1997 (https://landroverforums.com/forum/discovery-ii-18/help-starting-issue-stumper-1997-a-8325/)
rravenn13 Aug 17, 2007 07:06 PM
OK this is very very strange, please hear me out. My disco has had a random starting problem where it will not start and I have replaced the fuel filter and the fuel pump relay I thought everything was cool but it just started doing it again. Here is were it gets strange I was trying to check to see that the fuel pump was working. When I open the back door it starts! then I shut the back door and it wont! Open it again and it starts! Any ideas would be great!
Thanks!
Disco Mike Aug 17, 2007 08:09 PM
RE: HELP! Starting issue stumper 1997
The fuel pump will only run for just under 5 seconds when you turn the key. If the engine isn't actually running the fuel pump won't run.
rravenn13 Aug 17, 2007 11:03 PM
RE: HELP! Starting issue stumper 1996
OK my theory has been tested all night! No joke it will not start unless i open the rear door! And then when I shut it it might start fine for a few more tries.
Landzu Aug 18, 2007 07:07 AM
Check ground wires.
rravenn13 Aug 18, 2007 10:04 PM
Can someone please direct me to the location of the ground wires?
