help with travel of fox shocks
I have a land rover discovery II with 4 inch terrafirma lift i was wondering what the best fox shock travel would be for my vehicle? Would coilovers be an option in this scenario?
Originally Posted by Anson Cone
(Post 597310)
Originally Posted by Luckyjayb
(Post 597333)
they would be a pia. If you are looking for a factory fit, look at lucky8 and call or email them. I know the fox shocks they have are great for a 3 inch lift but not sure about a 4 inch. If you are open to other options, call Great Basin rovers. They do the blistein and can set you up with remote resivior or something heavier if you want. I would say coilover shocks would be overkill period unless you have medium duty springs and keep it fully laden but that's just my opinion. I'm sure the others will chirp in with some good advice also
I have FOX shocks in 3 inch and they are exceptional. They can custom manufacturer anything, just call them up.
Originally Posted by Faulk
(Post 597363)
You need to whip out the old tape measure and pencil whip the numbers. All of the compressed and extended lengths for FOX shocks is on their website.
Measure from upper mount to lower mount while your truck is sitting level, that's your shock length at rest. Let's say its 25". An 11" shock has the following specs: Ext.Length:28.10" & Col.Length:17.10" That means you'll get about 3" of downtravel and 8" of uptravel. So see where you're at and figure out how much uptravel and downtravel you want and buy the right length shock. |
| All times are GMT -5. The time now is 02:42 AM. |
