Here she is 1999 Discovery
You said you found the transmission check plug in the cup holder. Did you check the trans level. This isn't just a oh it's good check. You need to cycle through each gear and for each gear add fluid. If you have not done this you have no info to tell if the truck has fluid in the trans. this is the place to start. if you have done this and have a full level then we can talk more advanced diagnosis.
Northeast Arkansas. It threw a "P0722" code which is why is said troque converter, I downloaded "THE MANUAL" crazy how long it is.
moneypit37
17
07-31-2006 03:03 AM
