high lift jack carrier hack
thought I would share this mod. It is not quick release but it is a solid and inexpensive way to mount a hi lift. about $50 all in
start with a jegs spare tire carrier mount Part Number: 555-81092
remove the lug nut covers on the spare tire lug nuts, on my rig they are threaded all the way out
slight modification require to the mount, see photos
weld the mount solid, see photos
install stainless washers as thin spacers to the back side of mount see photos, this accounts for the convex shape of the factory wheel
about a 1 inch bolt, washer and lock washer to mount to tire,
I used some hardware I had lying around to mount the jack, I felt the mounting system was not quite up to snuff from jegs.
mount
mount totally flush
washers as spacers on back
welded
test fitted
finished and painted
final mounting hardware
mount
mount totally flush
welded
test fitted
The following 5 users liked this post by baileyrockhound:
cvhyatt (05-26-2022),
Discorama (05-25-2022),
gecko951 (05-27-2022),
JohnZo (05-25-2022),
Richard Gallant (05-25-2022)
the tire carrier and hinge does not seem to even notice the weight of the jack.
there is no shaking or movement, the gate swings easily and true. according to hi lift the jack is 25 pounds
If the gate is so near it's weight capacity limit that it can't handle 25 pounds they would be falling off every day, i am quite sure it is engineered with more than enough tolerance in its load capacity that 25 lbs wont hurt it.
mollusc (05-26-2022)
