High oil psi at idle. Clog?
Yep, the heat transfer characteristics of the two fluids (oil or water) will be different and also based on velocity, viscosity, densisty, thermal conductivity, specific heat, pipe diameter, etc. So one will reach temperature faster, and I suspect the oil lags the water. Some crusty old Mercedes service managers have told me you need to drive their vehicles 18 miles to get the oil up to temperature before an oil change. Running engines for short periods is rough service, example would be a fork lift that must suffer the stress of cranking and is used to unload one pallet, then parked outside again for days or weeks. Oil never gets warm enough to do the best job, cook off condensation, etc. But other forklifts that run all day long (like at the port near me) can have 18,000 hours on the engine.
Point I'm getting at is that lots of short trips, and guys that go a month on a tank of fuel, that is arduous service and should be treated as such (no 7500 mile oil changes, etc.). Battery has a hard time charging back up as well on short trips.
I just got it out for a 30 mile run. It will definitely get used tomorrow. I saw that rotella makes a triple T 10w-30. Do you think that would be better for my driving?
If you're referring to the noise I posted about months ago, then no I haven't. That noise comes and goes and I'm guessing it's the flex plate based on that it only happens while in gear. The lifters were replaced about 5k miles ago along with the HGs, a bad liner, and some bearings. I say some bearings because I'm assuming at least the main bearings were replaced when the liner was fixed. I have a receipt from the PO for $6k worth of engine rebuild for a slipped liner done by a respected indy shop right before I bought it. Since I drive only short distances, I should probably use a oil that is thinner at cold starts. Bob the oil guy used 5w20 in a Ford Expedition for this very reason (short trips and oil not reaching proper temps) and he had good results. I need to research it more, but I'm anxious to hear of any experiences with changing oil type in situations like mine.
Rover says xW30 is good for up to 95F ambient. And the 5w20 is rated for use from -35C to -10C (-31 to +14F). That's not enough in the summer. 5W40 Rotella would work on a wider temp range. One or two miles is just not enough time for the oil to come up to full temp. People in Birmingham know a thing or two about hot metal, they have a big statute of Vulcan on a hillside.
