HMMM lot of part left over??
Well guys I am replacing my head gasket and I have the engein down to the block and in th emiddle of rebuilding the heads! My question is I picked this set up http://www.roverparts.com/Parts/STC4082BK.cfm Look how many dif sizes and shaps I have not seen any of this during the break down??? How can I find out where all of the rings and etc goes this set is all in open bags in a box no # or names!!!
Thanks guys
Thanks guys
It's kind of scary after you get your cylinder heads off and you look at your engine bay and then look at your garage and the big pile of parts and bolts. Everything goes together a lot faster than it came off. Getting all those bolts off is the hardest part. Good luck let us know how it goes. Don't skip getting the cyl. heads planed
Man I hope your right Getting all those bolts off was hell and five trips to Nampa Auto in the work van.
Also I noticed the cyclender will rock very very slightly also if I fill up a cyclender head with degreaser it will leak through? What do you think about that?
Not sure as I recall though I left some coolant sitting in mine overnight (did not see it after removed the heads) and it did not leak through. Degreaser may be a different story but why are you spraying degreaser in the cylinders?
Well its all done and she started first try!!
Man that Sucked but I know for shure what it was cleaned and done with care I even rebuilt the heads my self, not bad for a guy with Zero exp LOL.
So I have only slow drived arround the block with the fresh cheep oil and old hp-3001 oil filter now how long do I need to drive or run it before new filter and good oil change??
Thanks
Thanks
Here is some pictures of my head gasket job. I had already completed the induction cleaning with Seafoam and the throttle body cleaning and ran a can of Seafoam through the gas, but look how dirty the air plenum was when I pulled it apart. The intake manifold was just as dirty. Had a bit of varnish inside too. This was my first major job on an engine and it was not as bad as I expected. The swivel impact socket set is a must along with the impact extension set. I used 5 cans of carb cleaner to clean my intake and plenum. I found 1 intake manifold bolt was not real tight and the rear valley pan gasket bolt was loose. The upper bell housing was very dirty.
