-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Hola (https://landroverforums.com/forum/discovery-ii-18/hola-20520/)
basquiat Mar 11, 2009 07:04 PM
Hola
Greetings
I wanted to ask for some assistance. I have had a 1999 DII for about 6 years now (114000 miles). The car has been good overall. I kinda of got used to having the CE light stay on. About 1 year ago i had a local mechanic do a major tune up (02 sensors, wires, plugs, and some other minor work). The car ran fine until about 3 weeks ago when i started noticing radiator fluid always beeing low. I had the head gasket changed 2 years ago and it did not seem like it was leaking too much. I made sure i always kept adding fluid until i had time to research the source.
I was driving one night when i noticed the rpms drop during a stop sign. The car started running rough and at times it stalled and hesitated when applying gas.
I parked the vehicle and read the following codes.
p1184
p0172
p0175
p0103
p0112
p1171
p1174
Thanks to the boards i was able to get an idea to take care of the leak. I changed all hoses, head gasket(although it was not leaking), throttle body heater, thermostat, mag wires and although i bought a water pump i never replaced it(pita). I recently drove it and it seems to be holding radiator fluid. The car still showing codes and still idles rough at times. The last time i changed the MAF was about 4 years ago. Wondering if it could be the MAF again. Please advice. Thank you gents
Rafael
roverguy7 Mar 11, 2009 10:05 PM
sounds like a mafs
okdiscoguy Mar 12, 2009 09:37 AM
What king of air filter are ou running? Did they try to clean the MAF when the did the tune up? I agree with Dave, sounds like a MAF....
