-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Horn Quit Working!?! (https://landroverforums.com/forum/discovery-ii-18/horn-quit-working-35837/)
southernrover Nov 18, 2010 11:29 AM
Hey Everyone,
I have a 2004 Disco II S. And... randomly... my horn stopped working. For a while, if I hit the horn on the steering wheel it made a very faint noise. Now, it makes no noise at all. Should I just change the fuse out? Which fuse? If not, is it really serious? What should I do?
Thanks!!
discoklein Nov 18, 2010 06:21 PM
You don't need a horn, use the finger...ha ha
Fireman Nov 18, 2010 08:42 PM
First use DVM and establish you have voltage to horn. Then check fuse. Then check switch. Then check wiring. THEN give up and use finger... or install steel bumper.
lipadj46 Nov 18, 2010 08:43 PM
You probably need to replace your horns
lordmorpheus Nov 18, 2010 10:28 PM
agreed. If you heard a faint horn sound once upon a time, then that went away, the horns have probably failed. Certainly wouldn't hurt to make sure you are getting 12V to them before buying new ones though.
southernrover Aug 8, 2011 01:20 AM
how long would it take to replace the horn? i need to get this done asap to pass the virginia safety inspection.
southernrover Aug 8, 2011 01:23 AM
Land Rover - Parts, Accessories and Information
There's a low note and a high note horn. Bizarre they both stopped working. FWIW I am still getting the very faint horn noise, but no one can hear it unless you're standing next to car. Wish I could attach an audio clip.
southernrover Aug 10, 2011 12:46 AM
What is DVM and how do I "establish (I) have voltage to horn."?
It's coming very faintly from the driver's side of the car. Nothing from the passenger's side at all.
Does this sound like a bad horn or a wiring/voltage issue?
socalrovershop Aug 10, 2011 01:40 AM
most common thing to go out on this subject is the buttons themselfs , faint noise can also mean slight contact. check the buttons out first
