horsepower and torque numbers?
RE: horsepower and torque numbers?
There is not much you can do without spending a fortune onperformancemachine work, such as porting and polishing the heads or/and making it a stroker. There's no performance heads available like domestic v8's. You can put on some magnacorewires and performance plugs. If you have oversized tires like 265 or bigger you can install lower gears.
Willie
Willie
ORIGINAL: pilsner
so its 4.6 liter v-6 with 217 Hp and 300 ft/lbs at 2600 RPM?
what can i do to increase that w/o messing up my MPG?
no the 4.6 is in the disco 2's.
the jeep is a 4.0L inline 6 rated at 190/235.
your 4.0L disco is 187/250.
you up on power, but also up on weight.
