How the *$&% do you get a rear hub nut off a disc II?
This is a Right Rear wheel so theirs no way it can be reverse thread, correct?
I have torched it 4 times, hit it with penetrating oil.
I am using a 5' pipe over a breaker bar.
I have broken: 2 - 1/2" breaker bars, 3 - 1/2" extensions, a 1/2" drive ratchet, and a 1.25" socket.
I didn't forget to bend the locking part of the nut out of the keyway.
Ive also 2 different impact guns on it @115 psi, one of them is rated at 425 ft/lbs
its a 2003 with 113 miles on it, almost no rust. Has anyone had it this bad and figured out something I haven't tried here?
jycsalas, I have removed the wheel but have not tried to take the nut off with the truck in the air because it would only spin the other wheel. Why do you ask?
I got some PB, so ill keep hitting it with that periodically.
I went to 2 different shops today, one tried with a breaker bar and sent me away, and the other was too busy to look at it. I'll start looking at tire shops..
thanks for the tips
thanks for the tips
