How Accurate is the Cylinder ID in a Misfire Code?
I have a P0304 code that reads as a Cylinder #4 misfire. First of all, how does the computer know which particular cylinder is misfiring? I can understand how it would know a misfire is occuring in a bank (using the O2 sensor), but other than having an injector short, how can a specific cylinder be identified?
For what it worth, Cylinder #4 has good spark, is getting fuel, and has 155 psi compression. I don't have a leak down tester, so I'm not sure about that value.
I'm wondering if the misfire could actually be another cylinder(s).
Thanks for any help.
