How did Doug at AB remove the fan without a fan clutch tool?
I'm trying to replace my water pump, but I'm stuck at the getting the fan off step. In this video from AB, Doug gets it loose with a wrench and a rubber mallet -- both of which I've got -- no fan clutch tool:
This other video tells me I need to use a fan clutch tool (which I don't have):
Is Doug working sorcery???
Should I just suck it up, pay $50 for this: and return the fan wrench I bought?
If it hasn't been off in a while, it gets quite tight. You need a 36mm fan wrench and a mallet, and just beat the crap out of it. I've found that a wooden mallet (like for woodworking) works great, since you can get some good speed going on it and it transfers energy much better than rubber.
matt3502 (04-20-2023)
AHA!
I found this other video on AB -- looks like a long screwdriver should do the trick for me w/o having to buy the special tool:
https://www.roverparts.com/resources...e-discovery-2/
Edit: Yep, long screwdriver was all it needed. Fan is off.
hasullivan (04-20-2023)
Yep, the (lack of) belt was part of the problem -- looooong story, but I had to snip it with a pair of shears. Thanks for the advice though -- It did take a couple strong whacks in addition to the extra leverage
The following 2 users liked this post by disco_nap:
hasullivan (04-20-2023),
V50-M66 (04-20-2023)
