-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   How do you clear SLS warning light??? (https://landroverforums.com/forum/discovery-ii-18/how-do-you-clear-sls-warning-light-27828/)
rankar Dec 27, 2009 04:38 PM
Guys, I did a search but couldn't find a related topic on this.
Do you know how to clear an SLS warning light? I've installed springs and removed the ol' air bags and now want to clear the warning light.
Can this be done via ODB? Or is this a dealer job?
Thanks all
jeffo Dec 28, 2009 09:01 AM
I have recently replaced my bags with springs. You need to find someone with the correct scanner to have the slab unit reprogrammed from bags to coils. If you dont do this the ride height sensors will tell the compressor to come on all the time. You should pull the SLS relay in the engine compartment fuse box to avoid battery drain. To avoid the over 20 mph chime that the additional 2 inches of lift will cause, disconnect the ride height sensors. This will allow you to operate normally until you can have the reprogramming done.
rankar Dec 28, 2009 09:02 PM
Thanks for the reply. Definitely did yank the relay, so I don't hear the whirring of the compressor (I do miss that sound btw). It sounds like a dealer job then. I wonder how much they'll charge for that gem of a job...
Spike555 Dec 28, 2009 09:05 PM
Yes you need the stealer to do this for you, should take about 10 min and they will prob charge you for 1 hour labor.
rankar Dec 28, 2009 09:15 PM
I guess I can do what I saw this cabbie do recently, put a black piece of tape over the warning light... thanks guys for your help.
caiogaucho Aug 21, 2010 06:53 PM
It was exactly what I did! At least the battery is not discharged more!:)
[]'s
Caio
timmay7t Oct 22, 2010 10:55 AM
i pulled the fuses today. hopefully my battery will stay charged, i'll update in a day or two to see if it worked
timmay7t Nov 1, 2010 08:13 AM
it worked, now i don't have to keep the jumper cables on the front set anymore......
hilltoppersx Nov 1, 2010 09:09 AM
some indie LR shops may have an SLS reader as well. my local guy does and he didnt charge me a dime. (thats cuz i throw him business though)
rankar Nov 2, 2010 10:18 AM
I called Atlantic British and they've got a list of indie folks with the right stuff. They connected me with a shop about 12 miles or so from my house. Went to see them, 10 minutes or less of programming and $20 got everything squared away.
