How to fix Exhaust Leak...???
Welding is the best option, but if you do not have the ability to weld yourself then take it to a local muffler shop, these pin holes can cause more problems than you think. As long as the pipe isn't corroded and you have enough meat left on the bone then a decent shop should be able to weld for cheap. I would not recommend JB weld or a exhaust repair kit.
lipadj46
07-08-2009 07:41 PM
