-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   How to get this out , d2a td5 (https://landroverforums.com/forum/discovery-ii-18/how-get-out-d2a-td5-103312/)
buzzliteyeh Dec 2, 2020 06:42 PM
Hi a bolt has fallen in where the timing chain runs and is at the bottom , can I get to it by dropping the oil Catch or will I have to take the timing chain cover off as well
https://cimg6.ibsrv.net/gimg/landrov...84ba06b2d8.jpg
The small bolt/screw is at the bottom left ,beside the cog
https://cimg7.ibsrv.net/gimg/landrov...e7202c749c.jpg
Looking down it's on the right hand side next to the bottom cog/sprocket . Any advice and laughter accepted .
sodaparis Dec 2, 2020 07:15 PM
retrieval tool would be worth a shot, either the type pictured below or a magnetic telescopic one, should be available locally
https://cimg9.ibsrv.net/gimg/landrov...2cb6690f39.png
buzzliteyeh Dec 2, 2020 07:18 PM
Thanks for the reply , I've given the two that I have here a go and they are just too big ...
gecko951 Dec 2, 2020 08:34 PM
Couple of ideas...
1. If you have a magnetizer then find a small diameter, bendable steel rod, magnetize the end and go fishing.
2. Find small diameter tubing that can reach the hardware and attach it to your shop vac with duct tape and the suction should be able to grab the bolt.
buzzliteyeh Dec 2, 2020 08:48 PM
Mate i didn't even think of a vacuum ! I've just epoxied a magnet to a clothes hanger wire and will see how i go , but the vac will be the next idea
nashvegas Dec 2, 2020 09:00 PM
This is how the Defender guys do it
https://cimg3.ibsrv.net/gimg/landrov...59453798a4.jpg
Sorry, I am of no help.
