How many times should the fan clutch spin before it comes off?
Replacing the fan clutch and water pump today.
The fan was previously seized up.
I knocked the nut loose with a 36mm wrench, and the fan is moving again.
Question is, how many times does this thing spin before coming off?
Seems like if turned it to the left at least 100 times, and no give.
Here is a YouTube clip to my troubles.
Obviously I meant "knocked the nut to the left"
In the video you said that you hit the nut to the right? When you are standind in front of your truck looking at your engine you need to be turning the nut to the left towards the passenger side.
Spray the nut with some liquid wrench or WD-40 and let it sit for an hour or so then spray it again. Now with the wrench on the nut facing straight up toward the hood take a hammer and knock it to the left. It should break loose after a few good taps.
As for your original question, hen ready to spin off, it is rather long winded and will take a lot of turns before coming off.
You might also consider replacing the coolant cap as well as the t/stat at the same time and use a 180 degree soft spring t/stat for better cooling.
I have a 180 degree t-sat that should be here next Thur, and I'm ordering the cap now. Never would have thought cap would run $25..
