-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   HUB STILL LEAKING?? (https://landroverforums.com/forum/discovery-ii-18/hub-still-leaking-17812/)
jycsalas Dec 9, 2008 01:12 PM
HUB STILL LEAKING??
Hello All,
I am at work and need to order a socket big enough to remove the axle nut to replace my rear hub... What size is that nut? THANKS!!
Josh
discoxd Dec 9, 2008 01:38 PM
RE: What size is my axle nut?
oddly enough mine werent tight enough to require sockets to remove them....
Spike555 Dec 9, 2008 05:04 PM
XD-DII's have a single non servicable hub, like on a front wheel drive car.
http://www.roverparts.com/Parts/CDU1534L.cfm
JYC-I think it is a 24mm.
discoxd Dec 9, 2008 06:21 PM
crap... i think we've been over this before...[:@]
Spike555 Dec 9, 2008 06:49 PM
Its ok XD. No worries mate.
jycsalas Dec 10, 2008 07:41 AM
I called the parts dept at a dealer in Fl and was told it was 36mm by a mechanic... I have a 30mm socket and it is too small to fit over it. I have had misleading and incorrect information from dealers before so i was hoping someone on this forum could tell me. I can find out myself but not until the weekend. =(
Spike555 Dec 10, 2008 08:57 PM
Let us know what sized it is so that we may help others.
Sorry we couldnt help you.
jycsalas Dec 15, 2008 01:20 PM
Ok it is a 36mm nut.
But now i need to remove and replace the hub. I have removed the hub and of course the drive shaft comes out with it. I need to press the drive shaft out of the hub and press it into the new one.
Has anyone done this before? I think using some type of gear puller might work to pull it out. Any suggestions?
Thanks
Urban Panzer Dec 15, 2008 02:28 PM
The biggest problem is the re-torque of the hub nut, you will need a torque wrench that does 360 lbs ft.
jycsalas Dec 15, 2008 03:15 PM
Yeah I figured that would be a challenge... but thats no problem...I have a friend who works on big rigs who might just have the tool needed for that part. Other than that, you think a gear puller will do it? I guess its worth a try!
