Hylosil or RTV- any differences?
Hey everyone,
I am about to start assembly of our engine and was wondering if you guys use Hylosil or RTV and what are the differences. Also with a sump pan gasket are you still using a sealant or just straight gasket, the manual has no mention of a rubber gasket and only Hylosil. Thanks |
hylomar was a factory item, a lot of customers use it. I use RTV without issues.
Hylosil 101 is a Amine curing RTV silicone sealant.
http://hylomar.com/hylo-wp/wp-conten...y_TDS_2011.pdf Hylosil 607 is a Oxime curing RTV silicone sealant adhesive http://hylomar.com/hylo-wp/wp-conten...07_issue_6.pdf Hylomar universal blue is a non-setting gasket sealant: http://hylomar.com/hylo-wp/wp-conten...ue_Issue_6.pdf See the next post for where LR says to use them. |
I got this form another site:
STC50550: Loctite 5900 STC50551: Terostat 8586 STC50552: Loctite 243 STC50554: Loctite 648 STC3811: Hylomar 101 (Amine curing RTV silicone sealant - engineering grade) STC4404: Hylomar 607 (Oxime curing RTV silicone sealant adhesive) STC4600: Hylomar 3400 (Permatex Anaerobic Gasket Maker or Loctite 518) NOTE: This is the current list of sealant recommendations from Land Rover's Topix website (accessed May 2013). This information supersedes the sealants recommended in the CD version of RAVE. Sealants The following table lists those sealants which are used during repair/overhaul procedures covered in this manual; it is essential that the sealant specified for a particular procedure is used at all times. V8 Engine Sump gasket to cylinder block - STC 50550 Clutch/torque converter housing to cylinder block - Upper 4 bolts - STC 50552 'V' grooves at end of cylinder head - Inlet manifold gasket - STC 50550 Cruciform seal ends - STC 50550 Dipstick tube - STC 50554 Timing cover bolts - STC 50552 Engine Management System - V8 Engine coolant temperature (ECT) sensor threads - STC 50552 Manifolds and Exhaust System - V8 'V' grooves at end of cylinder head - Inlet manifold gasket - STC 50550 Manual Gearbox - R380 Gear selector housing - STC 50550 Selector housing bolts - STC 50552 Input shaft oil seal housing - STC 50550 Input shaft oil seal housing bolts - STC 50552 Reverse inhibitor shaft threads - STC 50552 Gate plate bolts - STC 50552 Gear case to extension housing - STC 4404 Extension housing bolts - STC 50552 Gear change lever yoke Allen screw - STC 50552 Gear case to centre plate - STC 4404 Detent plugs - STC 50552 Bias spring adjustment plate bolts - STC 50552 Transfer Box - LT230SE Bottom cover plate - STC 4600 Bottom cover plate bolts - STC 50552 Front output housing core plug - STC 3811 Transfer box to gear case bolts - Petrol and Diesel engines - STC 50552 Transfer box to gear case studs - Petrol and Diesel engines - STC 50552 Rear cover - STC 4600 Differential warning lamp switch(es) - STC 50552 High/Low selector warning lamp switch - STC 50552 Rear output shaft housing - STC 4600 Rear output shaft housing bolts - STC 50552 High/Low selector fork set screw - STC 50552 Interlock solenoid selector cover - Up to 03 MY - STC 4600 Interlock solenoid circlip - 03 MY onwards - STC 50551 Neutral sensor - STC 50552 Intermediate shaft retaining plate bolt - STC 50552 Side cover - STC 4600 Side cover bolts - STC 50552 Differential lock selector shaft detent plug - STC 50552 Differential lock selector housing bolts - STC 50552 Front output shaft housing - STC 4600 Front output shaft housing bolts - STC 50552 High/Low selector shaft detent plug - STC 50552 Input gear bearing housing - STC 4600 Rear cover stud nut and bolt - STC 50552 High/Low cross shaft housing - STC 4600 High/Low cross shaft housing bolts - STC 50552 Rear Axle and Final Drive Differential cover to casing - STC 3811 Differential cover to casing bolts - STC 50552 Differential cover to casing - STC 3811 Front axle Differential cover to casing bolts - STC 50552 Front suspension Drive shaft to hub - STC 50554 Rear suspension Drive shaft to hub - STC 50554 Rear suspension SLS air compressor bolts - STC 50552 |
Generally for seals in the oil or cooling system I use a non-setting or semi-setting sealant. This is on the principle that if bits come loose, they won't block passageways in the system. RTV will block passageways. Maybe this is just paranoia..
I've had a great deal of luck with Permatex Form-a-gasket No 2 sealant (black) for oil and cooling systems, although I have found that it works best with a gasket, it doesn't reliably substitute FOR a gasket. |
Thanks for all the replys,
Excellent list as well. Now are you guys using just the rubber sump gasket or gasket with RTV type sealant. Also the timing cover gasket, gasket alone or with sealant? |
