Still got the 3 Amigos
I have an 02 Disco with 150k, I was getting intermittent 3 Amigos. I don't have a Hawkeye Scan Tool so I took a risk and installed a Shuttle Valve because many sources said the Shuttle Valve is the cause 98% of the time. It was great for a week but today they came back.
Another person on this forum said I should remove the shuttle valve again, which can apparently be done without disconnecting the six lines, avoiding the chance of a stripping out the soft and aluminum thread in the module and the need to bleed the brakes. After I remove the shuttle valve, I should remove the internal connector jack and reroute the two brown wires to the outside extend the wires run one to a ground and the other to the green and yellow wire that is part of the large multi-wire jack on the right side of the module.
All I did before was change the shuttle valve but apparently it wasn't enough.
I am on the right track now?
Yes, this.
"Remove the shuttle valve, I should remove the internal connector jack and reroute the two brown wires to the outside extend the wires run one to a ground and the other to the green and yellow wire that is part of the large multi-wire jack on the right side of the module".
glassman66
04-19-2012 10:17 AM
