I WISH my radiator was the problem...
Old 01-12-2010, 01:02 PM
okdiscoguy's Avatar
Do the plug wires (8MM Magnacor) and plugs (Bosch +4) while you have the IM off to do the heads. Makes it a ton easier.
  #22
Old 01-12-2010, 02:18 PM
brianb883's Avatar
Actually, the truck got brand new OEM Dealer wires (The really expensive ones) about 2000 miles ago. I've got the 8mm magnacores sitting here, and will do that when I reassemble.
I put in Bosch Platinum +4s when I got the truck, and had nothing but misfires and problems. The mechanic I took it to for a second opinion said to never use bosch platinum plugs, and put in NGK copper core plugs. I've had zero misfires issues since.
Does anybody know how I can really verify that my head gaskets are bad? My wost fear is to get down to the block and find they aren't bad....
  #23
Old 01-12-2010, 02:49 PM
okdiscoguy's Avatar
Take it to a shop and have a coolant pressure test done. They can inject dye and check for leaks with a UV light. You need to see where it is coming from. If you can see it dripping out, get under the truck and search. Get an inspection mirror. Otherwise, take it to a shop.
The reason you had misfires is they put on the factory plug wires (the really expensive one"s) Copper plugs are fine with whatever wires you run. The +4's give you more low end torque, but they have to be mated with the proper insulated wires or you don't get all of the spark you need.
lipadj46
06-01-2009 09:47 AM
sandroverdisco
06-01-2008 08:54 PM
George Dow
05-01-2008 11:44 AM
BostonBB
09-18-2007 06:49 AM
car4sale
05-23-2007 09:37 AM
Quick Reply: I WISH my radiator was the problem...
