Identify this leak...please
So I crawled under my disco today to admire my new shaft with neapco joints. Looks good.
However I noticed drops coming from somewhere and I can not figure out where. I am also concerned about it being dexcool. The disco had a new water pump , hoses, timing chain and timing chain gasket replaced less than 2k miles ago. I called days ago to confirm that they did not use dexcool for coolant and they said they would have used prestone or something like it.
Never occurred to me that the coolant color was orange, like dexcool.
So one thing I am hoping is that it is not dexcool. Is there other coolant that shares the same color?
Secondly I don't know where the drips are coming from.
Ideas? Pic links below.
Ideas why that bolt is spray painted hunter orange?
Thanks!
http://i40.photobucket.com/albums/e2...6/IMAG2827.jpg
http://i40.photobucket.com/albums/e2...6/IMAG2826.jpg
http://i40.photobucket.com/albums/e2...6/IMAG2823.jpg
Thanks!
Look in your coolant recovery container to see what color you have. More than one brand comes in orange or red/orange. See http://www.tegger.com/hondafaq/overh...e_Mag_53_g.pdf
Dang, they did all that and did not toss in a new oil pump???
Looking upward from the crank position sensor - head gaskets or maybe valley pan if you are lucky (leaking out the back).
Have you changed your oil yet? Isn't that the oil pan drain?
