Idle issues / bumpy Idle
Hi everyone, I'm having the idle issue? I checked out the rough idle thread and never saw the final fix if there was one??
I have changed out coils ,plugs,!wires and maf sensor. Still having the same bumpy Idle? It did seem that when i Changed Coils and wires it ran better for a while. But started again?? Changed out maf sensor, ran ok during test drive, but in the morning same old again?? any help with this issue will be most appreciated! Made an appointment with my mechanic for Monday.. just wanna point him in the right direction!! Thanks again in advance! |
Try this
where your vacuum line coming from the fuel purge valve connects to your manifold disconnect it and block the port at manifold. See if that fixes it. |
Have you cleaned the Idle air control unit? I had a low idle on cold startup way back, ended up being a sticking IAC. Brake cleaner fixed it. Maybe not your issue, but it takes only a few minutes to clean and rule it out.
Sounds like something to check out.?? Where is it located?? And whats it look like?? And I will definitely check it out!!!
Thank you for the photo.. I'll check it out asap tomorrow.... and clean it with carb/cleaner....
thanks again. I'll let you all know how it goes tomorrow!! Crossing my fingers |
Get an obd2 reader dongle and download torque app. check to see what your maf readings and fuel trims are.
Originally Posted by Red5
(Post 720154)
Don't worry if the IAC valve rattles when you shake it. It's supposed to do that. |
| All times are GMT -5. The time now is 09:35 AM. |
