Installing a Temp Gauge on a 2003 Disco II
11 Attachment(s)
Here is a simple "how to" install a temp gauge on a 2003 Disco II. I went with the temp gauge from Glowshift. Tinted 7 Color Water Temperature Gauge
What you need: Extra 18 Gauge Wire (Red, Black, Green, Yellow) Splicing Pliers 3/8" Wireloom Teflon Tape Water Sender Attachment (32MM) 32 MM or 1 1/4 Inch Water Sender Attachment 2x "add a circuit" fuse taps 2x 3amp fuses and some wire connectors, Everything else including the temp sender comes with the gauge out of the box. First you need to wire up the gauge. I choose to "add a circuit" into the fuse box. The "add a circuit" connector can be purchased at your local Autoparts store for about $5 each. Dont forget to get some 3amp fuses. The red wire needs to plug into a "switched" 12v source. The black wire needs to be grounded to the vehicle, I chose to ground it to a bolt near the fuse box. The yellow wire needs to plug into an "unswitched" source, meaning a source that has constant 12v power to it when the key is not in the ignition. This is what keeps your lighting settings on the gauge when you turn the vehicle off and back on. Attachment 46766 Here is my fuse box with the tap into the two fuses I chose for the red and yellow wires. Attachment 46767 Here is where I grounded the black wire right under the fuse box. Next run the green wire through the firewall and route it neatly to the temp sender. I decided to add a wire loom for protection and neatness. The loom actually houses both of my sender wires for the water temp and oil pressure. Attachment 46768 Attachment 46769 Next, cut your top radiator hose at the location shown in the picture and install the temperature sender attachment and temp sender. Dont forget to put some teflon tape on it. Connect your green wire to the white wire from the temp sender. (wire loom was not installed yet on these pictures) Attachment 46770 Attachment 46771 Attachment 46772 Attachment 46773 the black wire from the temp sender I grounded it to the battery. I also purchased a universal dual gauge A pillar pod and works and fits nicely! The only thing you lose is the left tweeter. I disconected it, or you can drill small holes in the A pillar pod for the sound to come out. Here it is! Universal Dual Gauge A Pillar Pod This is what my gauges look like. In the pics the oil sender is still not hooked up, that's why its ready max. Attachment 46774 Attachment 46775 Attachment 46776 Hope this write up was helpful.:D |
Nice writeup. What a beautifully clean engine bay!!!
Nice job.
Thats a great writeup. I am hoping to do this on Friday for the oil pressure gauge. I was going to pull off the beige A-pillar covers and paint it black. to match the gauge pillar pods . I looked all over eBay for black Discovery's interiors but looks like they are all beige A-pillar arms in Discoverys. I'll be going for the all black look. Thanks for the wiring directions. I will have to find the add a circuit at the auto parts store. I'm now waiting for your oil pressure write up. Are you going with the Sandwich oil adapter or making a brass T fitting on the front cover to incorporate the current pressure gauge?
Originally Posted by bosshogt
(Post 195970)
tito5590805 Where did you find the dimming wire to patch into? The positive and ground wires are pretty simple.
Here is a kit worth considering for the small sender (oil) hose off the front cover and a tricked out CND'd connector for the factory oil sender & electric pressure gauge. The 10,000 psi hydraulic hose included in this kit seems trustworthy. I knew there had to be a lot of race guys doing this mod.
http://www.namotorsports.net/detail....-022/xref/base |
(Post 195995)
Yup! That Kit will NOT work.
(Post 195993)
